Changing Front grill
big davey
I am interested in changing my grill to the new balck cupra one. have been told the whole bumper has to come off to change it?:confused: Can any one help! Was quoted at the dealer £75 to remove the bumper as it would take an hour! Can it be changed without this hassle and cost?
Igor23
Growing old disgracefully
Dec 7, 2006
495
Loughborough
Yes it can be changed, but you have to be strong, it's a bitch to remove, no you don't have to remove the bumper...
big davey
I had a go at doing it and it felt as though the clips inside were going to break. whats the procedure of getting it off then. Dont worry im strong mate.
Moley RUFC
Up in the Lickeys........
Nov 20, 2006
1,232
Lickey,Worcs
You need to prise the 2 clips upwards from the outside. It takes a fair bit of effort to do but it is possible. I was just amazed at how heavy the grill was.
big davey
Ive took the two pins at the top out, where are the clips inside the grill??
Moley RUFC
Nov 20, 2006
1,232
Lickey,Worcs
They are on the side of the grill attached to the bumper. If you bend the grill out (extreme force) you can see them. I have put a mesh grill on and only used the 2 pins at the top to fix it on as the grill didnt come with side fixings
big davey
is there no threat of breaking these clips though when you pull it forward. So i have to pull the two clips upwards and then does the grill just lift out?
Moley RUFC
Nov 20, 2006
1,232
Lickey,Worcs
I'm sure there is a danger of the clips breaking. I used a long thing flat head driver to push the clip away from the grill. If you just pull up the grille wont budge until the clips snap off. You need to push the clip in whilst pulling the grill up
big davey
Cheers for that mate.
Any one else changed there grill if so how did they do it and did they have any problems.
140SPORT
53
I took mine off and it was not easy at all I broke some parts but it went back in ok and does not move.
I am going to be taking it off again soon to swap it for a black cupra one so hopefully it will come out a lot easier.
I would just go for it ,You do have to put an extreme amount off force in to get it out which it strange for what the part does you would think it was holding the whole front together.
big davey
what so you broke the clips as well. I cant believe it is this difficult to change a grill seems strange to me.:confused:
