changing engine oil on a 1.4TDi
tdi_chris
2012 Leon 1.2 Tsi Copa SE
Apr 6, 2007
180
West Bromwich
www.myspace.com
Is there any way of changing the engine oil on a 1.4TDi ibiza without having to suck it out via the oil filter???
Can i not just drain it off like a petrol?
This is the 1st diesel i've owned so i ain't got a clue!
Is there not just a sump i can unscrew and drain it???
I don't want to change the oil filter though
Thanx :bleh:
Nath.
The Gentlemans Express
Jan 1, 2006
8,620
16
EASTLEIGH, HAMPSHIRE
yes diesel's have a sump plug
just drain it as normal and replace the filter
fitting a new sump ring is a good idea or just warm it up with a blow torch to make it supple again
go for it :D
kris_tdi
108
Why would you not want to change the filter? they are only £5 from the dealer.
kris_tdi
108
not you you wally
quote from tdi_chris
"I don't want to change the oil filter though"
