Right this weekend or next ( assuming bracket parts turn up etc ) I'm going to be replacing all the brake calipers on the Cordoba. Mk4 Golf rear calipers with goodridge hoses, and LCR brembos with goodridge hoses.
So I need someone to explain how I'd go about doing all this?
So far I've read, give the joints a good soaking with WD40 or similar ( I've got some release spray from halfords that seems better than WD40 for loosening rusty nuts and bolts ) and then a million and one different ways of doing the job. Engine running to keep the ABS pump going seems to be a must.
So could someone explain what I need to do? At the minute the old calipers are still connected up to keep crap out of the system. When I unbolt these will the old fluid all p**s out?
I bought an EZ-bleed kit a while back but it has no instructions with it so no idea how that works
I'm assuming I'll need the car up on 4 axel stands to do this job since I'll need access to everything. Best go buy another two...
Pete
Pete
