changing bulbs
waynejacobs
wayneo
Aug 10, 2006
107
cambridge
hi guys,
done a search but cant find anything that tells you how to change light bulbs on my leon,ive got a side light out and a brake light to any ideas please guys????
Reg
Professional Detailer
Oct 10, 2005
962
Berkshire
Its in your manual?
Failing that, a rear light means you pop open the cover in the boot to get access to the lights and change the right bulb.
On the front, offside is accessable straight away, just unclip the two spring clips and remove the plastic cover to get to the bulbs. If its nearside you need to undo the first two screws on the black cover nearest the wing, slide that up and out of the way, that gives access to the same thing - unclip the springs and hey presto.
