yes: open the tailgate, and you will see a single torx head screw half way down the inside edge of the light cluster. Remove that and ease the cluster sideways away from the centre of the car. There are 2 lugs which locate in rubber bushes inside the outer edge of the cluster, it will pop out then. Then remove the two phillips screws from the back and the bulb holder assembly unclips.
