This has got to be the easiest mod i have ever done to a car. Its well documented that the reverse bulb is the only one not LED with the full LED lights.
Basically open your boot. Slide the plastic cover on left side of the boot lid. Twist and pull to get bulb holder out. Change bulb and reverse procedure. Job done.
Bogao 1000 lumens Extremely Bright Error Free Canbus 921 912 W16W 45pcs 4014 Chipsets LED Bulbs For Backup Reverse Lights, Xenon White (Set of 2) https://www.amazon.co.uk/dp/B075FLZ6S1/ref=cm_sw_r_cp_apa_fu52AbGN2HPXQ
These are the ones i got. No errors on canbus!
Sent from my SM-A520F using Tapatalk
