central locking
twig
77
Guildford
If it's the same as the tdi, I think it's under the dash, somewhere towards the top. I think it's possible (but difficult) to see from the passenger footwell. Easy enough to get to with the glovebox off though.
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
remote ecu part is under the dash and from memory stuck under the dashtop between the glove box and the stereo
the main pnematic pump assy is in the rear 1/4 panel RH side behind the rear light tucked in by the back of the fuel flap all covered in a foam block
killer205
206
sorry forgot glovebox/airbag - still as long as you don't turn ignition on you won't get a light
what's happening with it ?
The central looking use to work but soon as i left the battery disconnectd for about 1 month that and the toad imobilizer dint work at all i duno wat the problem is :S
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
trying to remember which fuse it is but make sure all the wires are reconnected battery wise (easy done) but as it's perm live you may have sparked the battery back on and popped a fuse ?
wierder things have been known
killer205
206
i have checked all the fueses under the drivers side there all ok any idear
cheers m8
