central locking
varley16
67
my central locking doesnt work, so i need to reprogramme the key, and to do this i need another key (i think)
can i reprogramme my current key if i got aother one cut? or is a dealer job?
lc_allan
Northern Monkey
Sep 15, 2006
3,389
The re-programming only requires another standard key. Instructions are in your user manual :)
varley16
67
ok, so i can just get another key cut, will this need to be programmed so i can switch ignition on/off?
lc_allan
Northern Monkey
Sep 15, 2006
3,389
If you don't have a spare key then you'll also need a virgin transponder (about £6) to program the immobiliser. This can be done by someone with VAG-Com providing you have your cars 4/7 SKC code. If not then you'll probably need to get it done at the dealers. A new 2nd flip key can be sorted for about £30ish from ebay. You'll just have to get the blade cut and transponder programmed.
