central locking synchronization
h8kky
51
alrite guys, just went out to the car and the central locking would not work from the remote? works fine doin it manually tho, i just changed the battery and its still the same! could some1 check the owners manual for me please as i have left mines in work! thanks
JimyFloyd
234
Stick key in ignition....turn on electrics. Pull key out.....hold lock button....then press unlock three time and release the lock button.
The central locking should react and hey presto! Key recoded :D
cupra44
260
I got the same problem 1 of my key's don't work, Gonna go see if that little trick work's really hope it does, It wont lose the code to my other key will it???
cupra44
260
Just done it and it worked !! it didn't work the 1st few time's but then i held unlock and pressed lock 3 times instead of holding lock and pressing unlock, Thank you very much Jimy saved me a hour's labour from Stealer's
cupra44
260
ok so it worked but now my other key won't work !!! I can make each key work bt remote but it's only 1 that will work, So guess it is going into stealer's after all unless someone out there can help me !!!
