Central Locking Not Working
cupra tda
64
My Key Fob Will Not Unlock The Doors On My Cupra. I Have Just Had To Change My Car Battery And Its Not Worked Since. Ive Tried Matching The Key Up As It Says In The Book But With No Luck. Any Ideas Would Be Greatful.
scouse_sootie
I've got exactly the same problem on a 2000 TDiS. Tried using VAGCOM to communicate with control Module using 35 & 46 but neither seem to work (unable to connect to either). Have found module mounted under the top of the instrument pinicle but cannot remove instrument panel (seems to big to fit through gap). Do you have to remove steering wheel or does the Black panel from the 2 switches above the Radio display to the light switch come off.
