I need to pin out which pins are which on the central control unit (the one just under the steering wheel)
I'm specifically after the horn as i've just changed my slip ring, which still hasn't fixed the problem.
I've had vag-com on showing no faults and the output test makes the horn sound !
So I imagine its the wiring to the steering press switch?
Any help would be great and you'll be in my good books forever.
