CD Multi changer
Bowks
Not sure if this has been asked before but........ has anyone had problems with their 6 disk mutli changer.....? :confused:
I've got an 04 Cupra R with built in sat nav but i'm constantly having trouble with the unit in the glove box trying to read my cd's.
All the cd's are original (i.e not copies) but i'm finding it very frustrating that sometimes the cd's are found and all the other times it comes up with CD errror.... :censored:
Anyone know of a quick fix or is it back down the dealers for a moan......! i've tried a cd cleaner disk at that hasn't worked either.
BlackCupraa
2.0 BOOST
Sep 18, 2004
581
Chesterfield
Mine does this this as well
I took it back to the main dealer and they said its cos i had a few "Back up" cds in there
took it in again without them and they still did nothing :w4nk:
So i am waiting for Seat uk to tell them to issue me a new one
flashbsd
yeah i get this, i ran a cd lens cleaner through mine and its never done it since :D
JmZ
ZZZooooommmmmmm!
Nov 20, 2002
259
around and about
it is worth checking to see if any of the CD's you are trying to play have any form of 'copy protection' software installed by the record label.
This used to cause me lots of problems, so I stopped buying copy protected cd's.
All is fine and dandy now!
Bowks
Looking back through old threads i've found the below...... i might try this tonight and see how it goes, failing that its down to the dealers...!!!
Mine was hopeless, totally unusable, I used to get "Error" and "CD Error" about 80% of the time. There are a pair of fingers with rubber pads which remove the CD from the cassette to load it into the player. The fingers were pulling the CD out, but losing grip before delivering the CD to the player. Hense "Error". The rubber pads can be cleaned using alcohol, i.e. from a tape head cleaner. I used a cotton wool bud with one end soaked in the alcohol taped to a thin piece of plastic as an extension. No dismantling is required, it takes about 30 seconds. My changer now works perfectly and does play CD-rs.
MattR
Yellow...
Mar 18, 2002
151
Coventry
The fix is worth a try...
My unit errored the same, did in the V5 too, and in the TT. Have replaced it with a Sony T70 MP3 changer and no more probs...
Bowks
Just to let you all know, over the weekend i tried the cotton bud trick and it worked a treat. :D
I didn't use tape cleaner fluid though, instead i used Lucas brake disk cleaner which works exactly the same and evaporates without trace, so shouldn't affect the cd player in anyway! :clap:
If anyone’s having the same problem its worth a go before you have to spend out any money!
corradophil
228
Essex
Bowks, glad it worked - it was me who posted the info originally. I find I need to clean them once every couple of months, as the problem eventually returns, but it's easy to do so not a problem.
c11rgd
Freshie
Sep 27, 2006
166
Newbie
High guys got eh same problem just wanted to know has anuone got any pics of these finger in the changer, dont want to be poking the wrong thing. you know. thanks
corradophil
228
Essex
I haven't got a photo, and sold my Leon about a year ago, but take out the cassette which holds the 6 cds. Look towards the bottom of the space where it sits, you will see a pair of white fingers pointing to the right hand side of the player. Each finger has a small white rubber pad, these are what you need to clean.
c11rgd
Freshie
Sep 27, 2006
166
thank
thanks mate will try it, it did it a again today so i gave it a light tap and it worked lol/ thanks
SteveH
Phil C one word for you LEGEND.
Gave this a try as mine was playing up now works fine. I can drive to work and don't have to listen to fat Chris Moyles
Foxy
200bhp **** member no. 1
Oct 25, 2003
193
Daventry
www.pug306.net
Didnt work for me :(
Sometimes it just says 'changer' then switches back to the radio, sometimes it says 'error' and sometimes it starts to play only a horrible pulsing noise come through the speakers for about 1 second before it switches back to radio.
No copies in the magazine and I cleaned the bits and cleaned as much as I could internally.
corradophil
228
Essex
Foxy, I only had 'error' or 'disc error' come up on the display, never 'changer', and I also never got a oulsing noise. Sounds like you have a different problem.
It may be worth disconnecting the changer, and reconnecting it, to illiminate the possiblilty of a bad connection. You need to remove the changer from the glove box, which is very easy, and then you will find the plug behind it.
To remove the changer, unclip the plastic trim which goes below and to both sides of the changer, then remove the screws this reveales.
corradophil
228
Essex
Update! I have just repaaired a freinds one, in her LC.
Cleaning the fingers, made no difference, in the end I founf out the drive motor which spins the cd was sticking, so I gently washed it through with a small amount of wd40, then cleaned all components to make sure none was left in there. It now works perfectly, so there's something else to try, all be it a little more complex, because it requires removal of the changer from the car, and dismantling of the case.
Ljones
my old ibiza used to do this too completly random, eject cartridge and re-do and it worked
