CD Changer compatability with aftermarket stereos?
sonic_vi
Toledo 20vt
OK
so basically i want an aftermarket headunit but want a nice easy transition and would like to keep the factory cd changer active (for lazyness reasons :happy: )
anyway is there any aftermarket convertor for the seat cd changer?
I would like a pioneer headunit ideally
cheers guys
Russ
Nov 27, 2006
1,204
www.cardomain.com
A Panasonic player will work with a bit of messing to make an adaptor (just a few wires to splice)
Don't know why no-one makes these off -the-shelf but I could give it a go if you don't fancy it.
There may be other options ..... I'll see if I can work out a Pioneer option ;)
sonic_vi
Toledo 20vt
nice one
that would be cool
let me know
how much you looking at to make one up?
Aug 29, 2006
822
Poole
Spose you could buy another make of CD changer, or get an IPOD compatible HU and buy an IPOD, or get a HU that takes DVDs and burn MP3s on to it?
Aug 29, 2006
822
Poole
Head units easy! 2 slots at the bottom of the unit. Stick somethin flat and thin in both or get the proper removal keys from Hellfrauds (some have used jigsaw blades,spoons,screw drivers etc...) Make sure you have the radio code before you remove it though, unless your not bothered about it.
Aura Headunit Removal
That link will give you a bit more info too![B)]
Aug 29, 2006
822
Poole
Cool!
Decided to buy a Pioneer HU this afternoon after feeling sorry for myself because I'm ill [B)]
Looks good with the red illumination. All I gota do now it replace the speakers, add a sub and a couple of amps, then I'm done!
Nov 27, 2006
1,204
www.cardomain.com
Found the Pioneer changer interface
http://tradeonly.raysmith.co.uk/product_info.php?cPath=52_61_102&products_id=11921
Need to see a picture really, but I refuse to believe it can't be made to work
...and that no other headunits can control the factory CD changer is rubbish -
Pansonic adapter
So electricity can only travel in one direction down these 12 wires if you swap the plugs :confused:
822
Poole
Pansonic adapter
I understood it that these didn't exist! Cheers for sending me the link. Just signed up and will prob order one to test.
Nov 27, 2006
1,204
www.cardomain.com
If it's got a bit of clever conversion circuitry, it perhaps won't work
but the Panasonic adapter (above) is made up of a straight wiring loom - find out which pin controls what and wire one up :)
RobM
Back from the dead...
Sep 27, 2006
4,982
Southampton
Becker headunits have worked with VAG changers for a long time. In fact, a few months back I set up a Mexico Pro in a Polo GTi running with the standard changer. Worked a treat.
