cd changer cable
blak ice
67
where do I plug the other end of the cd changer cable?
I recently found out that the car end of the cd changer cable is not ppluged into the radio or where it is ment to be!
i pulled out the radio and and the climate control bit and i still couldnt find where the thing goes!
i wanna get a cd changer asap so i need it 2 b plug in!!
any ideas.... i have a mk3 ibiza...pre wired round 13 pin
Nov 27, 2006
1,204
www.cardomain.com
The boot end's 13 pin ?
Picture below is of the back of the Leon headunit - you should have something similar ... if not a square hole to plug it into, at least a slot it'll go into the right-hand side of
My immediate thought if you're struggling to find it was aftermarket changer cable fitted by a previous owner ??
...or you're just not looking hard enough :p
blak ice
67
at the back of the radio are a bunch of coloured blocks.
the cable i found is a round 13 pin and not a coloured block like the 1 in ur pic.
I will have to have yet another look at where the blue block is connected.
blak ice
67
ok...well i saw the blue block...that is connected to another set of blocks in the foot bit on the passenger side. one of the cable from the passenger set of blocks looks like its run down the car im not sure....
[:@] this is getting my annoyed
