Wasnt getting excited mate
As for fitting, its pretty easy. You remove 2 screws from the slam panel that hold on he inlet, remove the inlet duct (will need spider leg grips for the clip that holds the inlet to the engine cover). Then unclip engine cover to the turbo intake pipe, disconnect piping to DV and remove engine cover (there is a knack (e careful not to break the engine cover).
Open engine cover, remove OEM filter, put in new panel filter, close engine cover, replace on to car (easier to put part to cabin side of car on first and pull it down and forward for front mushrooms. Reconnect turbo intake pipe and refit the pipe to the DV. Then screw on Carbonio to slam panel and use spider legs to connect it to the engine cover using the clamp that came off originally.
Job Done.
