carbon canister removal question
mitch2028
76
hi all i hope i dont sound stupid but i know you have to blank the inlet on the throttle body for the carbon canister but what about the hardline that goes down to the small nipple on the t.i.p just before the inlet for the turbo, blank that to?
ive done the n249 bypass and have replaced the one n112 with a resistor, ive also done the sai removal so i only have one vac line going to the other n112 can i remove this and not have a vac line going there anymore and just have one for the d.v?
hope it makes sense and i dont sound too daft, ive tried a search but cant find what i want :help:
cus
... Vag only!
Feb 8, 2004
1,713
Middlesbrough
www.nemm.co.uk
blank the one going to the TIP as well :) when i replaced my tip, i just put a bolt in the hole and clamped it
the n249 bypass doesn't need any n112 valves, they can be removed and replaced with resistors. all you need is a vac line from inlet to d/v and inlet to fpr. then rest can be blocked. (if i'm wrong about the n249 bypass, someone will come and correct me soon enough :redface: )
RickC
BUILT NOT BOUGHT
Dec 23, 2004
1,621
Lincoln
i read somewhere that removing this causes a few problems, cant remember who did it now, think its Robdon
mitch2028
76
apart from an eml and the possibility of fumes it aint going to be a problem. im gonna trace the line back to the tank and cut it there i think.
RickC
BUILT NOT BOUGHT
Dec 23, 2004
1,621
Lincoln
i dunno what problems that your talking about... i haven't had any side effects. no error lights, so engine problems. passed its MOT ..
hmm, ok, what do you do with the wire connector? does it throw up a fault when its unplugged?
ill have a look for that post of the problem.
cus
... Vag only!
Feb 8, 2004
1,713
Middlesbrough
www.nemm.co.uk
shouldn't throw a code as long as you have a resistor on it :) the same resistor you use for the sai and n249.
the pipe with the fumes can be extended and fed down the wing. i've done this and cant smell anything. even at a complete stop with the heaters on
RickC
BUILT NOT BOUGHT
Dec 23, 2004
1,621
Lincoln
RickC
BUILT NOT BOUGHT
Dec 23, 2004
1,621
Lincoln
what resistance resitor, could do with knowing this if possible?
one end goes to the inlet above the TB, where does the other come from?
Jan 8, 2007
2,958
Wiltshire
Reviving an old thread - what have people used to blank the throttle body connection? I've got some silicone pipe I could use with a bolt in the end but as it's so on-show someone must have thought of something that looks a bit nicer?
tarzan
cupra owner from norway
Mar 15, 2008
1,122
drammen norway
remember i saw someone used the line to the dv from it when you have moved dv to colde side
Jan 8, 2007
2,958
Wiltshire
Ah there's an idea, especially as mine is on the cold side now. What ID is that connection then Phil? Guessing you squeezed some 4mm vac hose over it?
Nov 2, 2004
9,335
South Wales
Wow that hose would be well short.
I used 6mm ID silicone vac line and it fitted nice on the TB connection and the nipple on the DV as theyre different sizes. Yeah it was a little tight on the TB connection but thats all good. :D
