car wont start ??
23mjh
49
cardiff
hi all hopefully someone can point me in the right direction,my car wont fire up for love or money,i dont seem to be getting much of a spark after a few hours or searchin on here im guessing it could be the crank sensor or the ecu,scanned it this morning got 18 fault codes !!! ive had 3 mechanics look at it n there puzzled really, checked all fuses relays etc faults are as follows
18010 power supply B+ terminal low voltage
16501 engine coolant temp circ low
16486 mass or volumeair flow circ low input
17834 tank vent open
17544 long term fuel trim add fuel bank 1 system too lean
sec air inj syst incorrect flow detected
17523 02 sensor heater circ blank 1 sesor 1 short to ground
17633 cyl 1 inj circ short to ground
17634 cyl 2 as above
17635 cyl 3 as above
17636 cyl 4 as above
17955 boost pressure contr valve short to ground
17525 02 sensor heater circ bank 1 sensor 1 short to ground
17833 tank vent short to ground
17843 sec air inj syst pump relay circ short to ground
17829 sec air inj valve circ short to ground
17697 turbocharger bypass vave short to ground
17522 bank 1 sensor 1 internal resistance too high
thanks for taking the time to read this any opinions welcome cos im goin fookin mental
23mjh
49
cardiff
thx fot the quick reply,no didnt think of that ill check in the morning cos its at work,shes been good to me for almost 3 years then this lol if it has got wet can it be repaired ??
s1l3nc3r
ASBO car.
Jun 30, 2008
1,558
essex
Looks like fuse of bad earth wire of somthing...since you have a lot of short to ground codes...
Have you cleared the coeds to see what comes back..??
23mjh
49
cardiff
it stalled on the way home the other day then wouldnt start ,scanned it came up with these codes it drove fine this morning no probs at all,i thought the same thing so i cleaned every earth i could find but still no joy.ive cleard the codes but havent scanned it again gonna do it in the morning
23mjh
49
cardiff
its all really started since i changed the battery bought it new from my work (vauxhall) but i had it tested 2 day n they said it is fine ?? couldnt get a 60 amp so they gave me a 65 amp
Mat
get a correct amp... as for the SAI codes, that's pretty normal. Mine comes on a lot............
23mjh
49
cardiff
ya think that could be a problem? buggers told me its fine to go up just not down but then again tha was parts staff n what do they know ( no offence :p )
