Car sits in any gear reving, no motion
Nutkin
Pop-a-Keg ya?
Aug 24, 2006
2,581
Schnaitsee
Happened last night driving back slowley got worse until my car will now just sit in any gear and act like no power at all is getting to the wheels.
I had to abandon it as no AA cover, is there anything i can do to bodge this or is towing the only option?
Danny_FR
Soot? Meh...
Mar 1, 2007
373
Blackburn, Lancs
So it revs ok but doesn't transmit power? Clutch completely gone? If it is, you can still drive it without your clutch but its crunchy and embarrassing!
Nutkin
Pop-a-Keg ya?
Aug 24, 2006
2,581
Schnaitsee
revs goes into gear fine, but no power to wheels?
how do i still drive it?
i was trying but it just wouldnt go no matter what i did? none of the gears engaged.
Nutkin
Pop-a-Keg ya?
Aug 24, 2006
2,581
Schnaitsee
Can you check the cables are making the shifter move on top of your box?
yes, im reasonably sure it is the clutch, but i dont know if this is regular behaviour.
When its in first gear, it would pulll then it would just pulll less and less until now it is just free reving like the clutch is depressed all the time.
Nutkin
Pop-a-Keg ya?
Aug 24, 2006
2,581
Schnaitsee
If it's gone i doubt it - tbh it's probably going to be a tow and ramp job :( Can you select gears but not just not use them? What does the clutch pedal feel like?
honestly everything feels fine apart from nothing goes, :( its booked into autotechnic in wokingham, i just need to find that dam towing eye and get someone to tow me there
Nutkin
Pop-a-Keg ya?
Aug 24, 2006
2,581
Schnaitsee
never mind its going to a vag specialist and being towed.
175 for Towing though.
I have a feeling there gonna turn my brown eye blue with this ordeal.
Seat Adam
Dirty Densel Driver
Definately sounds like clutch completely gone. Bit steep the price of recovery!
I have a feeling there gonna turn my brown eye blue with this ordeal.[/QUOTE]
I think your brown eye will be more red and sore by the time their finished!
Dec 31, 2007
1,479
Reading
Get onto www.quidco.com, sign up, go through to RAC and get the cheapest cover they do. Its something like £29 with £20 quidco. If you haven't used quidco before they keep the first £15 in quidco you earn, but then anything after that you keep. So the cover will cost you £24 at the moment with a free quidco account.
I downloaded my card straight off the website once I'd joined so if you did the same you could use it straight away.
Think they claim to only tow you 10 miles, but if the garage you are going to is closer than that then you sorted, and a years worth of cover.
Or has it already been towed?
lee_woollett
285
northampton
I had a drive shaft pop put of a gearbox once which caused these very same symptoms. Could get the thing in gear and clutch felt as normal. That's an easy thing to check :)
