Car not starting - lots of VAG-COM faults
jaypee
174
Well the car hasn't caused me any trouble for 3 years, so it looks like its about time! Car is turning over with a ocassional feeling of starting but never quite does.
I've commented and questioned what I think it could be, I was going to change the throttle body again as I have a spare laying around. I've also done the fuel filter change, sparks and checked the fuel relay.
Any help much appreciated before I change the lot! =)
10 Faults Found:
17953 - Throttle Valve Controller: Malfunction - Think my throttle body has had it again!
P1545 - 35-10 - - - Intermittent
18010 - Power Supply Terminal 30: Voltage too Low - Possibly a low battery from trying to start and messing around with it
P1602 - 35-10 - - - Intermittent
17976 - Throttle Actuator (J338): Mechanical Failure - Think my throttle body has had it again!
P1568 - 35-10 - - - Intermittent
16487 - Mass Air Flow Sensor (G70): Signal too High - MAF Replacing again or just come up because of not startnig?
P0103 - 35-10 - - - Intermittent
16621 - Manifold Pressure / Boost Sensor (G31): Signal too Low - MAP sensor faulty or just come up because of not starting? Or maybe because of the adjustable boost?
P0237 - 35-10 - - - Intermittent
16497 - Intake Air Temp. Sensor (G42): Signal too High - Faulty or because of not starting?
P0113 - 35-10 - - - Intermittent
17743 - Engine Torque Monitor 2: Control Limit Exceeded - ?????
P1335 - 35-10 - - - Intermittent
16885 - Vehicle Speed Sensor: Implausible Signal - I remember the speed sensor cable was a bit touch and go from some work on the gearbox where it got yanked about a bit...
P0501 - 35-10 - - - Intermittent
17840 - Secondary Air Injection Solenoid Valve (N112): Open Circuit - SAI removed and I havent resistored yet so would make sense =)
P1432 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes
Controller: 1J0 907 379 AF
Component: ASR 20 IE CAN 0001
Coding: 13404
Shop #: WSC 00000
1 Fault Found:
01314 - Engine Control Module - The ABS sensor I think has a damaged connector?
49-00 - No Communications
Skipping Address 15-Airbags
End
UPDATE:
Changed throttle body, tried disconnecting MAF, still same issues
Put Battery on charge too
Might try swapping out some coil packs? [:@]
keenocupra
81
stirling
alright mate a lot of those codes may be on the same circuit have u checked all ur fuses? some fuses feed diffrent parts of ur engine controller if there ok i think u may have a broken wire in the circuit that feeds these components. do the codes clear ? or do they just come back?
jaypee
174
Found the plastic round the ecu keeping the rain off, the mastic had gone, and the connectors were damp.
The coilpacks had failed too.
All fixed :eek:)
Also one of the injectors looks a little leaky round the edge? will it need replacing or cleaning? or maybe it is clogged?
Chez
151
Edinburgh
check out my thread on "car wont start"
mine ended up being a melted resistor behind the instrument cluster.
it's worth a check before replacing loads
