Not posted for a while as the car has been going well, apart from needing a new radiator and ARB bushes.
Passed it'm mot last week at 103k miles and needed - a stop lamp bulb.
I've had my Toledo for about a year now, and I've fixed all of the known water leaks - replaced the door ancillary carrier seals, cut small wedges in the door botton seals below the drain holes, got the cable grommet re-sealed etc. and my car seems totally dry inside.
It was an indoor swimming pool when I got it, but the stealer nicely dried it out before I picked it up.
However, after it has been raining the car rapidly mists up with a nasty damp smell coming from the vents. The only solution is to open the windows or stick the air-con on.
It then clears and the wiff goes away.
I suspect I have water in the ventilation system and suspect the pollen filter is wet, but on checking it is always dry.
I think it may be the seal between the pollen filter housing and the bulkhead, but before I start ripping things apart I was wondering if anyone else had this issue and what it was.
I have searched the other threads but no joy.
Thanks in advance for any help.
Cheers,
Neil.
Cheers,
Neil.
