Heya Guys
Im looking for a bit of technical help.
My car has been cutting out randomly while driving along.
I drive a Ibiza Mk2 1999 2.0L 8V
I have taken peoples advice and done the following:
Replaced ECU Relay
Replace Fuel Relay
Cleaned Throttle Body
New Dizzy Cap
New Rotor Arm
New Plugs
New Leads
New Ignition Coil Pack
But the problem hasnt gone away and its very intermittant as it might not happen for days or weeks,
while driving along the road the car will just cut out at random, Sometime the car stalls or the Rev's will drop dramatically then bounce back up.
Each time this happens i notice a clicking noise coming from the steering column, Fuse box area.
Ill try and explain the sound.
if you turn the ignition on in the car (so all lights come on the dash)
Turn the key back to the off position but if you leave it there and listen about 5 - 10 seconds or so you will hear a little click.
Im imagining this could be an imobiliser cutting in or fuel pump being turned off or something like that.
But if anyone has any information that could help i would be most appreciative.
Gav
Replaced ECU Relay
Replace Fuel Relay
New Dizzy Cap
New Rotor Arm
New Plugs
New Leads
Gav
