car cover
sparkie1984
sparky
Aug 17, 2008
1,005
evenin' all!!
after noticing a scratch on my boot (someone putting branches into the bin has scraped my boot) that wont polish out which im very very peed off at!
i want a car cover, something i can throw over with little aggro, i used to use a tarpaulin on my old car but it was a right pain in the arse, tieing (sp?) it down every night so soon got fed up of that!
any ideas appreciated as always :)
cuprachrissy
i think rogers has one. pm him and ask. i was looking to get one but just forgot!
cuprachrissy
o you cheeky so an so, im only 23! and from your username your older so :bleh:
sparkie1984
sparky
Aug 17, 2008
1,005
oohh good shout!! i am hoping to get hold of a garage asap, so dont really wanna spend a fortune on a cover, but i have no guarantee how long till i get a garage at present!
curryholic
169
In zomerzet
I used to have a classic car and the owners club really didn't like them as the cheaper ones trap condensation under and caused rot... admittedly not too much of a problem with modern cars ;) I hope!
Any chance for a carport?
sparkie1984
sparky
Aug 17, 2008
1,005
well actually i have my house one side of the drive and the back of some council garages the other so theoretically it could be done.
what about planning permission though? also i want to try and keep the car out of site as much as poss!
curryholic
169
In zomerzet
check the local council/planning website, usually there's loads of guides and you can fill in some of the sides and it's still a car port - not a garage! I think the regs are different if its a garage?!? Check with planning though!
rogers
rogers
Jan 8, 2006
999
bridgend, south wales
always spend that little extra on a qualtiy cover otherwise they will scratch it!
i bought one from coveryourcar.com, as was said above, if you read you can upgrade to a stormforce which is a fully breathable cover so you can put it on when its wet and it ul dry! you should so that mind unless its clean as the dirt will move with the cover and prob more chance it will scratch it,
the main reason i bought mine was i taking alot of parts off over the winter and not using it, so to protect from the weather, and there was builders accross the road doing a huge extention, and with them cutting blocks etc it was gettin absloutley stinking!
sparkie1984
sparky
Aug 17, 2008
1,005
thanks rogers, was hoping youd pop along :)
ill look into that, ive actually just been speaking to someone about doing a swap with them to get a council garage in my local block!
so pending the results of that i may not have to worry about it! although it may still be worth buying an indoor cover for the garage
thanks all!
