Car battery low
Oct 14, 2019
35
Hi all,
I haven't used the car for a while and just came back from holiday so I already had a feeling the battery would be low
Started the car today and it didn't sound the same as before and the battery indicator was on the dash so I have borrowed a CTEK MXS 5 to charge it and was wondering if I could disconnect the battery and take it in to charge it without any warnings showing up when I plug it back in?
Also, should I use the normal car mode or AGM mode on the charger to charge it?
Hi all,
If the car starts, just take it for a drive
Reactions: SuperV8
Oct 14, 2019
35
The car starts but just barely and it doesn't sound normal like it did before, there's some vibration in the engine bay
I had it serviced just before my holiday and all was fine but the engine light indicator also came on so I suspect there's not enough power going through the system
nd-photo.nl
4,193
346
The Netherlands
youtube.com
I can highly recommend a battery monitor, so you can see what is happening over a longer period of time. Other than that, take it for a nice proper drive to charge the battery and drive out moisture from the oil etc.
Mr Pig
2,836
1,035
How old is the car? The batteries typically last six or seven years, maybe less depending on usage, so if it's in that ballpark I'd just replace the battery. A healthy battery should start the car no problem after sitting for two weeks. My father in law's car hardly got used and it could sit in the garage for months and would still start.
I've swapped a couple of batteries and if you do it quickly enough you won't get any warning lights and the ecu will not lose any settings. Not even your radio presets. Have the battery out of the car for longer, all bets are off.
If you fit a new battery it's best to code it to the car. The ecu alters the way in manages the battery depending on its spec and age. If you fix exactly the same spec battery, apparently the ecu will eventually figure out it's dealing with a new battery and act accordingly but I'd still code the battery to the car.
nd-photo.nl
4,193
346
The Netherlands
youtube.com
The Banner battery in my Cupra had a production date stamped on it, might also be worth looking into. Similar to a DOT code for tyres
AP1GczPcE5syxxtOU5fSTyafUjDOrq2d0gaJmKNNP4BV0QPGZjwMN9F2ZCKJk6Defl-3wcyZIr6YXF3vFlERDWZuuZsqoPWDuI00ZFRQSYp4tG-J_XvJWBWqQC7MwF2MhHE0Um2_XaEtWP_ycvNQIXLbcXIObA=w1920-h1080-s-no-gm
