Car battery coded
EFF11
138
39
My car has the (almost standard) 59Ah EFB Exide Battery.
On OBD11 the access is:
Module 19 - Gateway
Security Code 20103
Adaptation
Battery adaptation
The entry is:
Rated 59Ah
Manufacturer TU3
Serial Number F50127R053 (zeros are always displayed with a diagonal line, but I can't do that here)
Technology EFB
The second line on the BEM sticker on my battery reads: TU3F50127R053. So the first three digits are the battery manufacturer code and the rest is the serial number.
If you don't have a BEM sticker you should have a Quick Code.
The most relevant information is the battery type and capacity to allow the battery management system to charge the battery correctly. The car can't store up-to-date data on every battery manufacturer and serial number. So that may only be available using ODIS ( if at all). Batteries are manufactured to rigid standards so the difference between manufacturers should be minimal.
If you have an EFB battery don't get a much more expensive AGM battery. You will gain nothing.
Woodygo
135
43
Birmingham
Hi thanks for information I just fitted new battery the seat dealer said now need to code them so told me I needed a 096 agm battery as it is stop and start so fitted and all the dash lights all come on done what they said it would so I started car loads of faults on dash drove about 100 meters and the lights reset them selfs like the dealer said they would?
