can't access central conv with vag-com
seatstu
209
I have a LC 2003 i'm running 409.1 vag com but it can't find central conv I want to check the sensors for the alarm are turned on, also can anyone provide instruction for setting alarm chirp. tried to search can't find instruction.
seatstu
209
yes ignition is on I have fixed the problem I disconnected the battery for a few minutes and then reconnected I can now get in.
Chemical Al
Trollied Member
Apr 6, 2004
2,043
Craven Arms, Shropshire
into mod 46 then go to addapt then as you increase the channely you will go through tis list -
01 - Key - Count = 1
02 - N/A
03 - Auto Lock - on
04 - Auto Unlock - on
05 - monitor - on
06 - Unlock - beep - off
07 - Lock - Beep - off
08 - Unlock - Blink - on
09 - Lock - Blink - on
10 - Adjustment - Alarm Horn - UK
just add 1 or take 1 from the code depending on what you want to do :)
