Can the chains on a v5 squeek?
cupralooks
More Power Needed
Jul 3, 2006
579
Hi All,
I get a sweek for the first few minutes after start up when the engine is cold and then dies off.
I thought it was the auxilery belt so I changed that today that did not make any difference.
Where are the chains on the V5 engine? Are they on the auxilery belt side or on the gearbox side?
Had a further listen and it seems like it is coming from near the throttle body area, but I cant figure out where.
Any ideas? Thought it could be a squeeky water pump?
Alex
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
power steering pump ? alternator ?
could be any manner of things
personally i usually aim some accurate squirts of duck oil about to see if the squeek changes/dissapears, little bit at a time will soon narrow it down if it is external - internal however is a different matter
cupralooks
More Power Needed
Jul 3, 2006
579
The squeek is no longer coming from the auxilery belt side, so Im not sure what it could be
