Hi all,
Was wondering if someone could have a look over my logs pls. Ran out of road before i got to the limiter tho! Car doesn't seem to be having any probs but would just like to know if the maf is ok etc for peace of mind if you know what i mean! First part of the log isn't full throttle just pondering about then i nail it! Car is a mk2 tfsi sport, running a revo stage 1 remap btw!
Also, why doesn't it say full throttle? And should my actual boost at idle be circa 1 bar!?!?!?
Thanks!
Code:
STAMP Engine Speed Engine Load Intake Air Mass Throttle Drive - Angle Sensor 1 Load Status Intake Air - Temperature Misfire - Sum Counter Self-Adaptation - Steps Counter Boost Pressure - (specified) Boost Pressure - (actual)
/min % g/s % °C mbar mbar
456.75 2080 24.8 10.78 8.6 Part Throttle 21 0 4 410 1010
457.65 2080 24.1 10 7.8 Part Throttle 21 0 4 390 1010
458.56 2120 22.6 9.5 7.8 Part Throttle 21 0 4 280 1010
459.47 2160 15.8 6.5 5.9 Part Throttle 21 0 4 300 1000
460.35 2160 16.5 6.94 5.9 Part Throttle 22 0 4 300 1000
461.26 2160 16.5 6.92 5.9 Part Throttle 22 0 4 320 1000
462.16 2200 18 8.33 7.5 Part Throttle 22 0 4 440 1000
463.06 2240 24.1 10.92 8.6 Part Throttle 22 0 4 450 1010
463.95 2280 25.6 11.78 9.4 Part Throttle 21 0 4 450 1020
464.86 2360 24.8 11.5 8.2 Part Throttle 21 0 4 380 1020
465.76 2400 20.3 9.61 7.5 Part Throttle 21 0 4 380 1010
466.67 2440 20.3 9.58 7.8 Part Throttle 21 0 4 380 1010
467.56 2480 20.3 10.17 7.8 Part Throttle 21 0 4 320 1010
468.47 2520 17.3 8.33 6.7 Part Throttle 21 0 4 300 1010
469.37 2520 15.8 7.78 6.3 Part Throttle 22 0 4 300 1010
470.28 2560 15.8 7.5 6.3 Part Throttle 22 0 4 300 1010
471.16 2560 15.8 7.61 7.1 Idle 22 0 4 310 1010
472.07 2520 15.8 9.03 7.1 Overrun 21 0 4 310 1020
472.97 2480 15.8 8.56 7.1 Overrun 21 0 4 310 1020
473.88 2400 15 8.28 6.7 Part Throttle 21 0 4 550 1010
474.76 2360 36.1 20.81 14.5 Part Throttle 20 0 4 2110 1450
475.67 2680 121.1 87.31 99.6 Part Throttle 21 0 4 2220 2290
476.57 3280 182.7 131.69 99.6 Part Throttle 20 0 4 2230 2290
477.48 3920 179.7 149.89 99.6 Part Throttle 19 0 4 2190 2160
478.37 4520 175.9 167.81 99.6 Part Throttle 19 0 4 2070 2050
479.27 5080 166.2 179.44 99.6 Part Throttle 19 0 4 1900 1900
480.18 5560 155.6 184.58 99.6 Part Throttle 19 0 4 1780 1830
481.08 6000 148.9 191 98 Part Throttle 21 0 4 1680 1710
481.98 6360 140.6 190.17 96.5 Part Throttle 22 0 4 550 1810
482.87 6520 22.6 13 12.2 Idle 20 0 4 310 1140
483.78 6320 17.3 25.72 14.5 Idle 19 0 4 310 1090
Thanks!
