Can clutch pedal height be adjusted?
phantombantam
NUFC forever!
Jan 23, 2006
627
Co Durham
Hi people,
Can anyone tell me if it is possible to adjust the height of the clutch pedal on an LCR. The height and biting point on mine is much higher than my old cupra's was and not as stiff either. Getting it serviced in a few weeks and will get them to do it if it can be done.
Cheers.
Drew1982ish
alreet lar - tell me if im wrong but is the clutch not self adjusting due to how warn it is?? i had a few problems with the clutch piston sticking on the shaft - when they finally replaced clutch and piston - everything(biting point) was exactly where it was before -
phantombantam
NUFC forever!
Jan 23, 2006
627
Co Durham
No mate, its been like that since I got it (only3500 miles) and now its got 17000 on but getting it serviced so was just wondering about getting it adjusted then if it was possible.
Cheers.
Wheely
176
The Sou' West
As mentioned, the clutch is a simple self adjusting hydraulic system.
So as adjustable as a brake pedal..............which you cant adjust either (unless there's air/leak in the system and it needs a good bleed to get it out (unlikely though).
phantombantam
NUFC forever!
Jan 23, 2006
627
Co Durham
Just wondered as biting point on my 53 cupra that i had was much lower and the pedal was stiffer than my current LCR.
Cheers anyway.
225-Cupra-R-04
You've got me concerned as my bite point is very high? Anyone elses LCR the same? :confused:
J@mes
e46psi.com ;-)
Jun 14, 2004
2,842
Cheers anyway.
this is normal!
i have driven 2 cupras and about 4 different LCRs... the LCR's clutch travel is unfortunately about twice (well a good third!) the length of a cupra and it is also lighter due to this!
its not a problem at all, although i personally would prefer it if the LCR clutch peddle was the same weight but half the travel length if you see wat i mean?!
