Can anyone identify these part numbers
chrisbond69
chris bond
Jun 11, 2005
1,297
Cirencester, Glos
ive been trying to sort out my car this weekend so looked through my parts boxes upstairs and cant find the parts i wanted but i have the following which i dont have a clue what there for can anyone tell me what they are and where they go on the car please,
sorry the list is quite big, i know they should all be for the mk3 ibiza cupra
N908 011 01 LOCKING PIN
N011 523 18 WASHER
N101 174 03 BOLT HEX SOCKET
6N0 609 657A BRACKET
N904 840 03 SCREW HEX HEAD
171 823 395 RETAINER
1HM 121 267 BRACKET
N106 483 01 SCREW
N014 740 11 BOLT
N019 533 10 BOLT
058 145 757C GASKET
N901 686 04 SPEED NUT
N101 092 10 BOLT
8N0 103 531 SCREW
N907 356 04 BOLT
N022 154 4 HEX NUT
N101 028 03 BOLT
06B 103 638 GROMMET
1L0 853 139 CLIP
058 145 791 WASHER
N901 752 03 NUT
N906 633 01 WASHER
N905 532 02 BOLT DOUBLE HEX HEAD
N020 024 1 PLUG
N021 276 2 WASHER
N100 246 01 TAPPING SCREW
6K0 823 493A GUIDE
N106 663 02 SCREW
444 955 647 PLUG
N014 740 11 BOLT
N102 096 05 BOLT
N904 968 02 TAPPING SCREW
N907 678 01 STUD
056 103 377 WASHER
N903 572 01 WASHER
N013 812 8 WASHER
N010 216 12 BOLT
N044 411 5 STUD
N101 277 07 BOLT HEX
N902 264 04 NUT
N100 012 04 BOLT HEX HEAD
N905 426 02 TAPPING SCREW
N013 814 9 WASHER
N106 483 01 SCREW
058 145 540 SCREW
N902 002 01 NUT
Many thanks in advance ive obviously ordered them for a reason just dont know where they go
thanks again
chris
chrisbond69
chris bond
Jun 11, 2005
1,297
Cirencester, Glos
ive looked on there for about the first ten fifteen items i pulled out of the box and it wont work on part number searches so i binned it off because unless you know where the item could be from your screwed,
cupra_matt
Audi Technician
Dec 15, 2004
1,362
Carlisle
N90801101 LOCKING PIN
N01152318 WASHER
N10117403 BOLT HEX SOCKET
6N0609657A BRACKET - bracket to hold handbrake cable on MK3 with drum brakes
N90484003 SCREW HEX HEAD
171823395 RETAINER - rubber mounting for bonnet stay
1HM121267 BRACKET - Goes on top of radiator on left ( retainer )
N10648301 SCREW
N01474011 BOLT
N01953310 BOLT
058145757C GASKET - turbo oil return gasket ( turbo end )
N90168604 SPEED NUT
N10109210 BOLT
8N0103531 SCREW - Leon 02-04 engine cover screw
N90735604 BOLT
N0221544 HEX NUT
N10102803 BOLT
06B103638 GROMMET - mk3 cupra plastic engine cover grommet
1L0853139 CLIP - Expanding nut for side skirt MK3
058145791 WASHER - manifold - turbo bolt washer
N90175203 NUT
N90663301 WASHER
N90553202 BOLT DOUBLE HEX HEAD
N0200241 PLUG
N0212762 WASHER
N10024601 TAPPING SCREW
6K0823493A GUIDE - MK3 Ibiza Bonnet guide, sits on wing top.
N10666302 SCREW
444955647 PLUG
N014 740 11 BOLT
N102 096 05 BOLT
N90496802 TAPPING SCREW
N907 678 01 STUD
056 103 377 WASHER
N903 572 01 WASHER
N013 812 8 WASHER
N010 216 12 BOLT
N044 411 5 STUD
N902 264 04 NUT
N013 814 9 WASHER
N106 483 01 SCREW
058 145 540 SCREW
N902 002 01 NUT
All the nuts and screws dont seem to come up.
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
ill check rest later as you have to spell out standard items (N numbers) differently
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
N90801101 LOCKING PIN - engine cover mounting pin
N01152318 WASHER - 5mm washer
N10117403 BOLT HEX SOCKET - M6x30 Allen head bolt / thermostat housing most common
N90484003 SCREW HEX HEAD - M12x1.5x82 front susp arm bolt (horizontal one)
N10648301 SCREW - m6x16 countersunk bolt (for holding drums/discs in place)
N01474011 BOLT - m6x16 allen head bolt - various usual abs sensor
N01953310 BOLT - m8x20 engine mounting bolt to subframe
N90168604 SPEED NUT - m6x23.4x16 self tapper speed nut/speaker washer
N10109210 BOLT - M8x30 hex head bolt c/cshoulder - various
N90735604 BOLT - M7x28 hex head bolt c/w shoulder - sump
N0221544 HEX NUT - M5 nyloc - rear boot handle + various
N10102803 BOLT - m8x98 hex head bolt - rear NS gearbox mount extrension > gearbox
N90175203 NUT - m6 hex nut shouldered - various
N90663301 WASHER - 5.1x18x1.5 engine cover washer
N90553202 BOLT DOUBLE HEX HEAD - m10x58 / m8x12 engine mount stud rear RH
N0200241 PLUG - 10x1x12 receptor for rear window bolt
N0212762 WASHER - xxxxx
N10024601 TAPPING SCREW - xxxxx
N10666302 SCREW - oval head panel screw 4.2x19 skirt mounting block bolt
444955647 PLUG - washer bottle spare hole blank plug
N014 740 11 BOLT - m6x16 allen head bolt - various usual abs sensor
N102 096 05 BOLT - m12x1.5x65 hex head bolt front subframe to chassis
N90496802 TAPPING SCREW - 5.3x22 standard bolt various
N907 678 01 STUD - m10x35 turbo exhaust stud
056 103 377 WASHER - 11.5x2 downpipe/cat washer
N903 572 01 WASHER - 8.4x17x4 exhaust manifold washer
N013 812 8 WASHER - m12x15.5 turbo oil feed banjo bolt washer
N010 216 12 BOLT - m6x18 rear main oil seal housing bolt
N044 411 5 STUD - m8x30 exhaust manifold stud
N101 277 07 BOLT HEX - m8x26 hex bolt - lower ball joint > susp arm
N902 264 04 NUT - m8 brake servo nyloc nut
N100 012 04 BOLT HEX HEAD - m8x55 subframe weight mounting bolt
N905 426 02 TAPPING SCREW - 6.6x19 self tap wing bolt+various
N013 814 9 WASHER - 14.2x17.9x1.5 seal washer turbo oil outlet
N106 483 01 SCREW - m6x16 countersunk bolt (for holding drums/discs in place)
058 145 540 SCREW - m10x50 ex manifold > turbo bolt
