can any one help me on my t.i.p
beaver69
ive just fitted it today and every now and again when i put foot down it miss fires:(
gazjones
you havent upset the wire's going to one of the coil packs fitting the tip have you? also are all your connections fine going to bits on the tip like n75, but prblem dosent seem tip related
Bogwoppit
1,085
Lincs
Doesn't matter then. If it was mapped I was going to say that the small gain that the T.I.P. has given you has shown a weak coil pack.
RichardBW
408
Leamington Spa
sounds like an air leak somewhere? Is the turbo connection good? sometimes the hose can pull off the turbo when the hose clip is tightened?
Is N75, dv, etc all plumbed in as standard?
