Does anyone have the part number? Either Main dealer number of GSF mart number?
I've searched and all the results just show people asking for the number, and just getting replies basically saying the timing will be out and that the sensor never breaks....
Mat i thought you have had a cambelt fitted? if so and its only just started coming up with this fault then your timing will be out it only has to be a tooth out to give this fault. just thought id let you know
Yeah, a lot say timing.... However, it took 4 attempts to start last night, and then 3 attempts when leaving the cinema... Which to me could indicate a dodgey connection...
Bingo! but its not preventing it from starting its just cant start because it doesnt know why the crank isnt in time with the cam so doesnt know when to put air n fuel in the right time. Also if its struggling to start id say its more than a tooth out!
feels like it's running fine... only thing i noticed yesterday is when I do about 30/40mph and 3rd/4th gear and not touching any peddles, I can hear a faint pop pop pop pop.... sounds like knocking..... To me, that's the timing
why dont you have a deal with him that if you go to another garage, they redo the timing and it works, he pays for it. if not then buy the sensor. at least you'll prove him wrong if your right...
mine brought this fault up when my cambelt had slipped, the car would start u just had to press the throttle 3 times before turning the key. mine had slipped 7 teeth and still ran fine, just had to do that to start it. i also had a new cambelt fitted and they put it on in the same place!! . brought my new sensor from euro car parts was about £35. not that it made any diffrence though. 7 teeth out didnt do any damage so if it has slipped i cant see that it would of damaged anything
