camber!
Adam180
95
Northern Ireland
hey ive been searching all week, i put coilovers into my ibiza cupra a week ago and dropped it 120mm, now i have about -1 degree of camber at the rear and plus 0.5 at the front, really need to adjust the front, is the car adjustable standard?
any kits availible? plz plz plz
Oj 89
Senior junior member
Aug 19, 2008
1,747
NW Kent
you sure about that drop figure mate? the bumper barely sits 120mm from the tarmac as it is!
My advice for the camber is get it done somewhere where they have laser alignment. Wouldn't recommend taking risks with something like that.
Oj
Ricardo_Smooth
Powered by Apples!
Jun 26, 2007
669
sheffield
but yes its adjustable as std, hence why its now all over since you've fitted your coilies. get it set up properly as guess work itsn't good for this i'm afraid!
Adam180
95
Northern Ireland
the front splitter is litterally cantching stones, i only drive to work in the morning so i thought id leave it like that for a few days and then raise it up, i had it booked in to get the caster camber and toe done 2moro but the guy said he doesnt see how it could be adjustable, neither do i, i fitted the coilovers and i cant really see what would allow any adjustment apart from the toe,
anyone does this and know for facts, any help at all pelase
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
If they guy doing it doesn't know, take it somewhere else!
However, it's the two bolts that secure the hub carrier to the strut
Ricardo_Smooth
Powered by Apples!
Jun 26, 2007
669
sheffield
anyone what?
loosen the 2 bolts move the hub/strut to where you want them and do em up
"simples"
there is plenty of slack in the holes to do the adjustment +/-3 degrees approx
yup i concur as it took me a while to set mine up as i wanted it set at 1 degree negative seen as it's a road car and everything bloody moves :lol:
Jan 8, 2007
2,958
Wiltshire
As Mork has said if that guy you've taken it too can't work out how to adjust the camber I sure as hell wouldn't let him touch it. People underestimate the importance of setting the geometry up correctly. Without it you're wasting your money on hundreds of pounds worth of mods. Hope you get it sorted :)
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
I think it was jason that had someone do the camber on his car, by winding the tracking rods right the way out.
It didn't work
Adam180
95
Northern Ireland
It didn't work
HAHAHAHAHAH love it mork,
thanks for the info, ill sort it out 2moro, couldnt even get it only a lift at my work and i would concider them low profile compared to others,
i fitted them at my cousins company, OBD autotune, highly recommend tuning company in Northern ireland,
and i had to use a snap-on low profile jack to get it off the lift legs and onto some planks of wood.
Adam180
95
Northern Ireland
turns out the camber is adjustable, not very precise but it is doable,
+/- 1degree i would say, so i have it maxed at -1 for the mean time until my H&R triple c camber bolts come, then ill get it done precisely
antnee
Have you actually read any of the replies? Camber is adjustable via the 2 bolts on the bottom of the shock.
AFAIK camber bolts are for car with only a single bolt holding the shock onto the hub
