camber degrees with lowered car
SeatR
399
Norway, Bergen
okey, i've searched but got no smarter. someone says -0.30degrees is original. and should be -0.5 lowered.
but someone else says -0.5 degrees is original.
what should i set camber for with 35mm lowering springs?
IbizaAlex
AKS tuning
May 11, 2008
532
Bedford
A Cupra R is -0.35 and i think the original is the same. On my Cupra its set to -2.10 degs thats lowered about 80mm and on my diesel ive set it at -1.30 degs and thats lowered about 45mm.
I dont get bad tyre wear on either car. If you want the car to handle well then i would go for beween -1 and -1.2 degs.
SeatR
399
Norway, Bergen
okey thnx, but one thing i dont understand then. when the car is lowered, i though the camber angle went more minus resulting in wear on inner edge on tire? and for compensate for this, would have to go less minus?
what im i getting wrong?
Im out for less wear and good handling yes ;)
so i should try -1.0 degree then?
Adam R
Diesel ISN'T a Dirty word
Mar 5, 2007
2,851
lee in the solent
as the car is lowered more positive camber occurs. to counter this you need to dial in more negative camber.
i am currently running -1 deg on my fronts and im pretty low (for me) i can get my thumb in the gap between the wheel and the arch. (im runnign 195/45/16 tyres.)
Jan 8, 2007
2,958
Wiltshire
I always thought it was more negative the more you lowered.
I've been lowering mine on coilies this week and need to get it aligned soon - is there a figure I should ask for when I take it in??
Righttoe
100% Welsh *******
Jul 21, 2008
220
Bexleyheath, UK
Mines on coilovers but i think its around 60mm down, maybe more, took it to local performance specialists and they said original is 0.5deg negative, but if i wanted better handling and not much tire wear to go for 1deg negative. so i did and all seems fine
Jan 8, 2007
2,958
Wiltshire
I've just rang Imperial Tyres in Swindon near me who assure me they can adjust the camber to an optimum configuration and have quoted me £120+VAT for a four wheel alignment and fitting and balancing four new tyres (I'm providing the tyres separately). Seems OK to me?
Jan 8, 2007
2,958
Wiltshire
Comes to £141 all in which admitedly isn't cheap but their reputation seems pretty good. I guess it's the balance between paying enough for a decent setup and getting ripped off. I may get a few more prices first.
Jan 8, 2007
2,958
Wiltshire
After a bit of digging around I've managed to get hold of some Rainsport 2's for £57.40 each inc VAT and delivery from Camskill, spot on :D
So, looks like 4 new tyres, fitting, balancing and full 4 wheel alignment is going to set me back £370 - although I think I can get them fitted/balanced by a mate so hopefully just looking at £70 for alignment
