Camber Adjustment Pics Needed Please
LeeroyBrown
Rite on!!!
May 7, 2005
359
Cornwall
Camber Adjustment Anyone help?
Just fitted H&R Kit on a couple days ago now.. Went to get it all tracked up at quick fit, they couldnt the the machine on the rear wheels, and they said i had positve front wheels and negative back wheel or other way round.. He had a quick look and said doesnt look like u can change the camber, but doing a search on here has proved me that you can?? I was just wondering if anyone has any pics on how u adjust the camber as i really havent got a clue and quick fit seem to be just as useless as me :lol:
If you aint got a clue what im chatting about then this pic should make it ovb!:D
Lee
Russ_20vt
Kitesurfing nut
Feb 4, 2005
468
T,Wells. Kent.
You adjust the camber by the 2 bolts on the bottom of the strut and by slightly adjusting the top mounts, but to do this by eye and a spirit level is near on impossible to get perfect. Your best best is to take it to a specialist (not the monkeys at kwik fit) that has 4 wheel laser wheel alignment and they will get it spot on. I paid about £45 for it to be done on mine.
LeeroyBrown
Rite on!!!
May 7, 2005
359
Cornwall
yeh kwik fit had that laser aswell when they done the traking but said that they would touch anything to do with the camber as they dont do that sort of thing:lol: Ok cheers mate ill have to find a "decent" garage..
Martin CUK
CruisinUK.com
Jul 13, 2004
322
NW
www.cruisinuk.com
It can definitely be done. The laser equipment Kwik Fit use isn't as accurate as the stuff I've seen at the proper garage I use either, I'd just stay well clear of them, lol.
Have you got rear spacers? That will help the rear wheels. You can adjust the front camber but at the expense of tyre wear. I could get mine adjusted in a bit but I don't want to go through my nice tyres quicker, lol.
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
If you can get yourself a digi spirit level you can do this yourself.
like said the strut to hub x2 bolts are for some adjustment.. roughly +/- 2.5 degrees on the "slop" in the holes.
For road use think somewhere between 1 & 1.5 degree's -ve camber.
You will need to adjust your tracking afterwards.
Been doing this all afternoon on badger wagen whilst setting new low ride height and swapping springs. Fiddly and time consuming.
