Cambelt replacement
grotmeister
168
gonna pull the engine out this weekend to replace clutch, to replace cambelt and jetwash the engine compartment. so i'm looking for advice on cambelt replacement. ie does the tendioner need replacing and is there any other stuff I should know?? All advice gratefully received!! cheers in advance
lunalupi
...is not a bloke!
Jul 29, 2006
953
Wiltshire
As Craig said - Cambelt, tensioners etc all need changing, plus the waterpump as you will have easy access.
You can buy a cambelt kit which should include all the bits (except the water pump) :)
