Cam sensor or crank fault, 1.6tdi
ibizamk5tdi
21
Not long into a journey after a cold start my 1.6tdi will cut out and refuse to start, leave it a bit and it's fine and the eml will no longer be on.
Here is the vcds scan, hope someone can assist. I have checked and cleaned the cam sensor as it was a little dirty but the faults below have returned.
Wednesday,12,October,2016,22:20:23:04550
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
VCDS Version: 15.7.0.2
Data version: 20150820
VIN: VSSZZZ6JZBR053564 License Plate: DA60CW0
Mileage: 121190km-75303mi Repair Order:
Chassis Type: 6J (6N0)
Scan: 01 03 08 09 15 17 19 25 44 4B 56
VIN: VSSZZZ6JZBR053564 Mileage: 121190km-75303miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
4B-Multifunc. Module -- Status: OK 0000
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CAYC) Labels: 03L-906-023-CAY.clb
Part No SW: 03L 906 023 BF HW: 03L 906 023 S
Component: 1,6l R4 CR td H13 8811
Revision: --H13--- Serial number:
Coding: 00114016002500080000
Shop #: WSC 99999 1023 2097151
ASAM Dataset: EV_ECM16TDI02103L906023BF 003008
ROD: EV_ECM16TDI02103L906023AH.rod
VCID: 6B3010A38A8A684A000CCA-803E
5 Faults Found:
6031 - Camshaft Position Sensor (G40)
P0341 00 [040] - Implausible Signal
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 29
Mileage: 121541 km
Date: 2016.10.11
Time: 07:43:52
6037 - Camshaft Position Sensor (G40)
P0341 00 [032] - Implausible Signal
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 31
Mileage: 121543 km
Date: 2016.10.11
Time: 19:42:04
6035 - Bank 1: CMP Sensor (G40) / Engine Speed Sensor (G28)
P0016 00 [032] - Incorrect Correlation
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Mileage: 121543 km
Date: 2016.10.11
Time: 19:40:30
6110 - Crankshaft Position Sensor (G28)
P0335 00 [032] - Malfunction
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 121543 km
Date: 2016.10.11
Time: 19:40:10
6039 - Camshaft Position Sensor (G40)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Mileage: 121543 km
Date: 2016.10.11
Time: 19:40:41
Readiness: 0000 0000
Sent from my SM-G935F using Tapatalk
propane94
Bearded Ginger
Nov 15, 2012
406
12
Portsmouth
A lot of this can be caused by an old battery/weak alternator. I would suggest checking those two first.
From the logs I see there is a crank shaft error as well. Also you have ABS and electric faults, could you post those in greater detail as well.
ibizamk5tdi
21
5 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 29
Mileage: 121541 km
Date: 2016.10.11
Time: 07:43:52
Freeze Frame:
Fault Priority: 2
Fault Frequency: 31
Mileage: 121543 km
Date: 2016.10.11
Time: 19:42:04
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Mileage: 121543 km
Date: 2016.10.11
Time: 19:40:30
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 121543 km
Date: 2016.10.11
Time: 19:40:10
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Mileage: 121543 km
Date: 2016.10.11
Time: 19:40:41
Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ABS82.clb
Part No SW: 6R0 907 379 AD HW: 6R0 907 379 AB
Component: ABS8.2 front H03 0001
Revision: --------
Coding: 100200DB007200B5082A00E800D500000000
Shop #: WSC 04941 000 00000
VCID: 00EA570F930C9712C53E55-8054
1 Fault Found:
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 0
Fault Frequency: 3
Reset counter: 191
Mileage: 121196 km
Time Indication: 0
Date: 2011.03.04
Time: 08:01:22
Freeze Frame:
Hex Value: 0x0005
Hex Value: 0x0000
Hex Value: 0x1012
Hex Value: 0x138A
Hex Value: 0x00FF
Hex Value: 0x007F
Hex Value: 0x7E00
Hex Value: 0x0000
Address 08: Auto HVAC Labels: 6J0-820-045.clb
Part No SW: 6J0 820 045 A HW: 6J0 820 045 A
Component: J301 Klimaanlage 0320
Revision: 00 25 08 Serial number: 0000000976759-
Shop #: WSC 06402 785 00200
VCID: 24A23B9F27D4AF328156D9-8070
No fault code found.
Address 09: Cent. Elect. (J519) Labels: 6R0-937-08x-09.clb
Part No SW: 6R0 937 087 F HW: 6R0 937 087
Component: BCM PQ25 H+4 H46 0221
Revision: BF046001 Serial number: 0345 216102478
Coding: 3C8829E888612500922000007E0B1CC80080400F608C0000200000000000
Shop #: WSC 64564 324 38760
VCID: 406A970FD38C531285BE95-8014
Subsystem 1 - Part No SW: 6R0 959 802 N HW: 6R0 959 802 N Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 003 3130
Coding: 030000
Subsystem 2 - Part No SW: 6R0 959 801 Q HW: 6R0 959 801 Q Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 003 3130
Coding: 020000
Subsystem 3 - Part No: 1K8 951 171 A
Component: DWA-Sensor 00 001 0103
Coding: 000000
Subsystem 4 - Part No: 1K8 951 605 A
Component: LIN BACKUP HO H11 9004
Coding: 000000
Subsystem 5 - Part No: 1K8 951 171 A
Coding: 000000
1 Fault Found:
00910 - Indicator Lamp for Emergency Flashers (K6)
007 - Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00100111
Fault Priority: 3
Fault Frequency: 1
Reset counter: 186
Mileage: 120736 km
Time Indication: 0
Date: 2011.02.24
Time: 13:45:36
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 6R0 959 655 K HW: 6R0 959 655 K
Component: VW10AirbagA05 H09 0020
Revision: -------- Serial number: 003GX006EW9R
Coding: 003035
Shop #: WSC 06401 785 00200
ASAM Dataset: EV_AirbaVW10BPAVW250 A01001
ROD: EV_AirbaVW10BPAVW250_SE25.rod
VCID: 4A7EB527E5B091425BDA67-801E
Crash sensor for side airbag; driver side:
Serial number: 3495RRB40676VQ8AEO5C
Crash sensor for side airbag; front passenger side:
Serial number: 3505RRB404T6VQ8AJGGW
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 6J0 920 902 H HW: 6J0 920 902 H
Component: KOMBI H05 0404
Serial number: 00000000000000
Coding: 410A00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04086
ROD: EV_Kombi_UDS_VDD_RM09_SE25.rod
VCID: 2EB6D9B77918DD6267F2AB-807A
Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 6R0 937 087
Component: GW-K-CAN TP20 0221
Coding: 422100
VCID: 700A07CFA3AC8392355E85-8024
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H05 0404
Serial number:
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03008
ROD: EV_Immo_UDS_VDD_RM09_SE25.rod
VCID: 6A3E15A7857071427B1AC7-803E
Address 44: Steering Assist Labels: 6Q0-423-156.clb
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 10121
Shop #: WSC 06402
VCID: 2F88C4B37E12486A6CE45E-807A
Address 4B: Multifunc. Module Labels: None
Part No: 6J0 959 441
Component: MF-Modul 0007 0001
Coding: 0000001
Shop #: WSC 77005 000 00000
VCID: 700A07CFA3AC4392355E85-8024
Address 56: Radio (J503) Labels: 6J0-035-153.clb
Part No SW: 6J2 035 153 E HW: 6J2 035 153 E
Component: Radio H10 0107
Revision: R0000000 Serial number: SEZAZ2K1069776
Coding: 0501040002
VCID: 28BA2FAF5BFC8B52ADAEED-807C
End-------------------------(Elapsed Time: 02:14)--------------------------
ibizamk5tdi
21
It's twice it's done it now, within 5 minutes of starting the car, cut out on the same stretch of road, same morning commute.
How would a garage pin point such a fault, would love to solve it myself as love tinkering! But suspect this one might be a garage job.
ibizamk5tdi
21
Thanks for that. I will look this weekend. When you mention earth point I assume you mean the main earth points like off the battery etc.
marijnensam
11
It looks like the 5 volt sensor reference is interrupted or pulling down beneath 5v. Can be caused by the ecu or an other actuator. Or the timing of your distribution is not right. Seen the mileage did it been replaced ?
Verstuurd vanaf mijn SM-G900F met Tapatalk
ibizamk5tdi
21
I have booked it for for a cambelt next week as it's due anyway along with a Service. They are going to look into the fault.
ibizamk5tdi
21
Well, new cambelt fitted, with a new cam sensor and Service, 4 weeks later the fault is back!
Can garages not pinpoint the route cause on intermittent faults? I know the cam and crank sensors work together but surely in today's tech mad world they should be able to replace the exact part!
marijnensam
11
Probably there be a break in the wiring. Between the sensor and the ecu
ibizamk5tdi
21
They have replaced the crank sensor, struck up OK, idled fine, went down the road, cut out again, same faults! They have checked all the wiring too so might have to get the ecu tested. They said they have never had a car like it!
ibizamk5tdi
21
Well it turns out the master technician was on holiday and the other guys only know how to do what the computer tells them and don't think outside the box! The timing had slipped a tooth, all fixed!
