they now do the loom for the 1.8 20vt and all uprated sensors to go with
youll be running a fixed map so it wont need (but you can if you want) to run an 02 sensor
you also have the option of running antilag (which you can turn off if you want like all rally cars)
Its for emissions crap when idling. The yanks swap out the VVT for the fixed type, so they are interchangable, but I don't know how the cam profiles differ (if at all).
I see your point. I hadn't considered the economics. Just had a look at the prices for my audi (so similar price to seat). Non vvt adjuster = £95 + vat. VVT Adjuster = £255 + vat.
Anyway, you can swap them over. If disconnected it should behave just like the non vvt item. Do a search on vwvortex.com, you should see a few threads on the subject.
