Need a straight answer to the following; What are the part codes for the cambelt + parts for an AQX engine? I'd also like the part code for the uprated water pump with the metal impeller.
06A121011T supercedes a couple of times to end up as 06A121012X which comes with the seal.
Does it have metal impaler Mike? I was under the impression that other members went outside VWG parts to get a suitable pump i.e. this part is not very good!!
Cambelt, tensioner, pump, seal is that all I need? Out of interest how much do you charge for the job??
Also been considering doing it myself but i've always left cam belts / chains to well known places due to having someone to blame should it be out nd feck everything up lol.
I still got the 011T as well but if you were to order it through the SEAT / VWG system it will supersede. I think all water pumps now spersede to an exchange part (part number ending in X)
Thre are so many pumps I can't remember which do and which don't (we don't stock them as they are exchange parts). I know that VWG modified at least some to give them metal impellors instead of plastic but they were not much better!!
