Cam belt not done properly?
Icecavern
6,214
Berkshire, UK
www.icecavern.com
Had the cam belt on the LCR about a month or so ago and yesterday the check engine light came on. Managed to read the codes out tonight and got
2 DTCs Found:
16396 - Cam-Timing Adj. Bank 1: Retard Setpoint Not Reached
35-00 - -
16727 - Camshaft Position Sensor (G40): Signal too High
35-10 - - - Intermittent
Does this sound like a co-incidence or is it likely the cam belt hasn't been fitted properly?
Going to be calling Camberley Seat tomorrow to try and get it booked in again but wondering where I stand
Pete
techie
Skoda Techie
Mar 22, 2003
5,438
Worcs
Bit odd though if its taken a month to come back on.
You usually get a camshaft correlation fault not those two anyhow. I think the first fault will cause the second anyhow. If the timing adjuster on the cam chain is sticking then it will throw the cam position sensor out.
MJ
Public transport abuser
Apr 22, 2008
5,508
13
Manchester
m.facebook.com
The tensioner damper could have failed or the tensioner come loose there are alot of possibilities, just take it back to the dealer and ask them to check the timing.
Seat Adam
Dirty Densel Driver
To be honest, I don't like Camberley Seat anyway, when I went in there they seemed like they didn't care about the problems my car had and didn't want to help. My mate has his car in there too and they had to remove the front bumper for a repair and didn't put it back on properly. It came loose and nearly fell off whilst he was driving it!
On the issue you have though, i'd check the tensioner damper as already said.
Icecavern
6,214
Berkshire, UK
www.icecavern.com
As an updtae, just got back form Camberley Seat. It's not the cambelt, but the timing is out. So they're having to strip bits down to find out the fault. Just by the look on the guys face I get the feeling this bill is gonna hurt :(
MJ
Apr 22, 2008
5,508
13
Manchester
m.facebook.com
The chain cannot jump but can become slack due to low oil pressure not acting on the hydrolic tensioner. This may cause a timming fault. The car would run fine without any loss of power but would have a slight delay at speed when accelerating and sometimes the oil light would come on, well this is something we have seen on some 20vt engines with 90k+ miles on the clock. The oil feed pipe tends to block up causing the above symptoms.
