Cable Drivers & Software Help
Essex_Cupra
466
It was recommended I buy a USB cable to use with Ross Tech VAG Software
The cable was delivered with a small CD with the drivers on which I installed.
I then proceeded and downloaded VAG software & Installed
Went into the program when link with my ecu and laptop and I get the error message "Ross Tech Interface not found"
So i'm guessing Drivers or Software i've downloaded is wrong!
Can anyone help!
Big_daddy
Going going gone.....
Oct 20, 2006
3,930
Brummy
youve got the wrong one, you need download either the 409 or 303 to work with that cable.
the veriosn only works with the orignal ross tech cable.
Theresias
Just read this page carefully and then proceed to the archives page to download one of the stone age versions... ;)
http://www.ross-tech.com/vag-com/download/index.html
Of course you also need to make sure the 3rd party USB<>RS232 emulation driver is properly installed and the port is correctly linked to be accessed by VAG-COM. You may want to contact the people you bought from too, they should know what's needed to get the stuff they imported from China working.:hide:
