As some of you know, since getting my Passat remapped I've been suffering from the dreaded clutch slip as many tuned PDs do. In this case it was anywhere between 2-3k rpm in 4th/5th/6th, even with light throttle application.
I asked Simon Coe to get me a revised Upsolute map, with slightly reduced torque between 2-3k rpm, but with a stronger top-end (without increasing boost any further).
Simon uploaded the new file on Friday, and I can now put my foot down at lower RPM in any gear without worrying about frying the clutch, but when accelerating hard at higher RPM I now have a bit more power than before.
Anyway - I know that a lot of people suffer from clutch slip but either can't afford the expense of an uprated clutch after forking out for the remap, or just don't want to go that far.
I thought I'd post up to show that if you choose a decent tuning firm, they should be able to cure the problem for you, with hardly any noticeable effect on performance.
At least I should be able to get a decent rolling road run at Awesome without the clutch slipping now
