Hi, my bulb check error suddenly appeared one week ago. I didn't do anything to the lights in my car, not any modification.
The error apperas only when I press on the brake, but there is not any faulty brake light, everything works as it should.
I tried to replace the brake bulbs anyway but the error still consists.
I scanned with my vcds and it says there aren't any errors...
Can someone help me with that?
Tuesday,21,June,2022,21:25:02:00009
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 20.4.2.0
Data version: 20200730 DS317.0
www.Ross-Tech.com
VIN: VSSZZZ6JZCR122048 License Plate:
Mileage: 112420km-69854mi Repair Order:
Chassis Type: 6J-SE25 (6N0)
Scan: 01 03 04 08 09 15 17 19 25 44
VIN: VSSZZZ6JZCR122048 Mileage: 112420km-69854miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
Address 01: Engine Labels: 03C-906-024-BXW.lbl
Part No SW: 03C 906 024 CD HW: 03C 906 024 CD
Component: CGGB MM4HV G 8548
Revision: --H09--- Serial number:
Coding: 0000071
Shop #: WSC 06402 785 00200
VCID: 62CB1F8FBE4FB89665-515A
No fault code found.
Readiness: 0110 0001
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 BC HW: 6R0 907 379 AF
Component: ESP8.2i front H05 0002
Revision: --------
Coding: 110224DB216F00B4882524E684D900401300
Shop #: WSC 04941 000 00000
VCID: 000F350797030A8613-8054
Address 08: Auto HVAC Labels: 6J0-820-045.clb
Part No SW: 6J0 820 045 A HW: 6J0 820 045 A
Component: J301 Klimaanlage 0330
Revision: 00 26 08 Serial number: 0000002364209-
VCID: 24475997E7DBF6A657-8070
Address 09: Cent. Elect. (J519) Labels:. 6R0-937-08x-09.clb
Part No SW: 6R0 937 087 K HW: 6R0 937 087
Component: BCM PQ25 H+4 H46 0254
Revision: BF046001 Serial number: 0434 024120816
Coding: 64882BE888610100002008F06E0B0CC800C0002F608C0000200000000000
Shop #: WSC 64564 324 38760
VCID: 4581E413CCA1EFAE60-8010
Subsystem 1 - Part No SW: 6R0 959 801 M HW: 6R0 959 801 M Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 002 3110
Serial number: --------------------
Coding: 020000
Subsystem 2 - Part No SW: 6R0 959 802 P HW: 6R0 959 802 P Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 002 3110
Coding: 020000
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 6R0 959 655 K HW: 6R0 959 655 K
Component: VW10AirbagA09 H09 0020
Revision: -------- Serial number: 003GX012X2TX
Coding: 003039
Shop #: WSC 06401 785 00200
ASAM Dataset: EV_AirbaVW10BPAVW250 A01001
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 4A9BD72FEDBF00D68D-801E
Crash sensor for side airbag: driver side:
Serial number: 3495RRB405T11GSI892Z
Crash sensor for side airbag: front passenger side:
Serial number: 3505RRB405T11GSID9M9
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 6J0 920 803 HW: 6J0 920 803
Component: KOMBI H02 0504
Serial number: 00000000000000
Coding: 110201
Shop #: WSC 131071 1023 2097151
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
ROD: EV_Kombi_UDS_VDD_RM09_SE25.rod
VCID: 66C3039F9967C4B689-8032
Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 6R0 937 087
Component: GW-K-CAN TP20 H46 0254
Revision: BF046001
Coding: 022200
VCID: 70EF65C7A3A31A06E3-8024
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H02 0504
Serial number:
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03009
ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
VCID: 6ADB77AF8D7FE0D6AD-803E
Address 44: Steering Assist Labels: 6Q0-423-156.clb
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11211
Shop #: WSC 06402
VCID: 2F6DA6BBEA1D45FEBA-807A
End-------------------------(Elapsed Time: 02:08)--------------------------
