BT parts/part numbers + info
Olly20VT
1,234
Stroud Glos ,England
I have searched but no answers.
I'm thinking of going IHI in the next 6 months.
I know i need a S3/LCR fuel pump but does any one have any part numbers? or any other fuel pump that is the same + part number?
I have read lots on injectors, i know that Jabba use 440cc green tops (LCR) but I've also read that the spray is not to good so what would anyone recommend + cost + part numbers and place to get them?
I'm also thinking of putting a MK1 golf external fuel pump in line to make sure I've always got the pressure, i know some people have this. Does anyone know the part number of them as well.
Also jabba use a "Exhaust gas temp. sender" what is this? Is it just a lambda probe or a uprated lambda?
ANY info on any of this would be a grate help + if you have any advice.
Olly
Dec 31, 2005
1,856
London
Im doing the same, hope to be going ihi in the next 6months but im gonna save up and get it done rather than do it myself.
Have you asked Bill?
karl.w
methanol junkie
Oct 26, 2005
606
Are you going to try and DIY IHI? Who is going to map it for you as i here that Jabba wont map it unless you get them to do all the work:shrug:
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
lol, he knows where i am and we've been thru this list before :rolleyes:
440's give adequate supply.
consider some genesis injectors if wanting new
I have some used 440's which I used to run on way back when. (without issue)
3" DP is back with me
TIP for VF34 also....
many cast offs
garage sale-lol
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
egt sensor is for new 7.5 ecu's not crappy ibiza ecu's like we run. unless wanting one for aux guage then type k thermocouple and a dvm with thermocouple input to keep an eye. if doing guaging then wideband is more important (egt blummin good idea mind you especially on an ihi)
Olly20VT
1,234
TIP for VF34
:doh:
I'll still have the DP and i'll also buy the injectors and TIP from you please bill.
I hope to do a DIY IHI to help cut the coasts down, and stay with custom code through bill, i know that doing it this way i have no come backs but garentees are such a gray area anyway.
Still now answer on fuel pumps though ;)
