Aimez
Drove home last night from work no problem. Turned off car for maybe 10 mins got a call from my friend drove out to meet her and no sounds, I mean the only sounds were coming from the sub and the headunit works fine. I have a 4ch amp connected to my door and rear speakers and another amp powering my sub. Can anone help is it just a fuse maybe sick of driving to work in silence!
Check the fuse in the amp - did you run seperate feeds from the battery to each amp? Can you s ee if the amps protection light / power light is on? Has the remote turn on lead come away from the amp?
There's a few suggestions to get you going :)
sub is on taht's all I can hear is bass notes!So i presume the 2 ch amp running the sub is running spearatly as it is okay, the other amp powering my speakers doesn't appear to be on. I did not install this in my car so I haven't got much of a clue as you can tell! I
