Broken MAF Maybe?
Funkyfin2000
Black Leon Cupra R 280bhp
Oct 6, 2005
2,477
Stafford, Staffordshire
Hi Peeps,
I have been doing some searching and its hard to get a definite answer so don't flame me for not searching
Coming up a hill near my house today, and went to floor it, there was a slight jolt/bang and the traction control light came on......then a few mins later the engine management light came on.
Hooked it up to VAG.com and came up with the following errors:
Address 01 -------------------------------------------------------
Controller: 6K0 906 032 AA
Component: 1.8L 20VT EU3 0002
Coding: 10500
Shop #: WSC 00000
1 Fault Found:
16486 - Mass Air Flow Sensor (G70): Signal too Low
P0102 - 35-00 - -
Readiness: 0000 0000
Address 03 -------------------------------------------------------
Controller: 1J0 907 379 AF
Component: ASR 20 IE CAN 0001
Coding: 13404
Shop #: WSC 00000
1 Fault Found:
01314 - Engine Control Module
79-00 - Please Check Fault Codes
I believe the engine issue is the same problem as the MAF one.
I took a look at the engine to find any blown of tubes or anything and couldn't find any. And checked for split hoses and couldn't hear anything.
I have let the car run and then pulled the MAF wires out and the car runs as normal at idle, if i try and plug it back in whilst running it nearly stalls.
The car runs as normal still though or as it did before...with the MAF connected (not tried it not connected) and boosts fine or as it did before. It isn't in any kind of limp mode.
I have cleared the codes and once revving the faults just came back again.
I have a 007 Forge DV and a Piper X induction kit on it (fitted about 2 months ago)
Any helpers would be appreciated.
Ive read it could be a fuse? if so which one??
Could i get any readings out of VAG.com to find out if it was definetly the MAP knacered...
Rich
Funkyfin2000
Oct 6, 2005
2,477
ive done it under log group 003 and got the following data:
Are you saying i should be logging it under measuring block 002?
Sunday 15 October 2006 15:55:44
6K0 906 032 AA 1.8L 20VT EU3
Group A: '003
RPM Mass Flow Load Ign. Timing
TIME
MARKER STAMP /min g/s % °BTDC
1.07 840 0.08 1.6 11.3
1.47 840 0.08 1.6 10.5
1.87 840 0.08 1.6 9.8
2.27 840 0.08 1.6 8.3
2.67 840 0.08 2 18.8
3.07 1760 0.08 13.3 22.5
3.47 2240 0.08 2 5.3
3.87 1880 0.08 2.4 5.3
4.27 1720 0.08 13.7 26.3
4.67 3520 0.08 27.5 1.5
5.09 3280 0.08 3.5 17.3
5.57 2640 0.08 2.4 15
6.08 2520 0.08 31 18.8
6.64 4000 0.06 14.1 13.5
7.07 3800 0.08 3.5 14.3
7.58 3080 0.08 3.1 15
8.08 2400 0.08 2.7 12
8.48 1880 0.08 1.6 5.3
8.88 1400 0.08 1.6 10.5
