After giving the rear brakes a freshen up i noticed my n/s front brembo has a crack in the laquer and is holding water giving it a sort of frost look has anyone refurbed there calipers as it dont look to appealing at the momment
Rub them down with a fine grade wet & dry paper but be careful not to rub off the Brembo stickers. Don't go down to the paint, just rub the lacquer off. Then give them 4 or 5 coats of new lacquer and they'll be shiney red again!
Cheers jamjay i am very please with them PITA to clean though.
When i had my brembo's done i found the red is not painted on but powder coated so if you brushed brake fluid (carefully)on the calipers the lacquer will peel off a treat, then spray with a degreaser and re-lacquer.
I really want to respray mine (i've done the lacquer thing) but I don't know what paint to use, a similar shade to OEM, nothing illuminous. I saw a thread where the guy used Halfords high temp and they were too bright for my liking.
