Brembo Brakes
zex789
I've just bought a LCR from a garage and im finding the brakes to feel pretty soft, i dont know if its because my last brakes on a seat ibiza were heavily servoed or if the brakes need bleeding. the pads have been changed all round and i dont know how strong the brakes should be. Can any one make a suggestion?
:cry:
halfsleeve
soft brembos
yep,have the same problem,i've just changed all 4 sets and now they feel quite soft,where as before they were very responsive to the slightest touch.
Tried bleeding ,still the same ,feel fine when the engine is'nt running (pump up nice and firm),once engine is started and servo kicks in the brake pedal when depressed gives off a slight hissy airy noise as if there is air in the system.....maybe it needs to stand overnight then rebled i don't know,but i'll try anything............:shrug:
IS THERE ANYBODY WHO KNOWS WHATS WRONG:think:
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
bleed them with pressure bleed and decent fluid.
they can be a real pain to do sometimes and soft pedal is not uncommon when theres trapped air somewhere.
also... are the brakes worn? (rears also?)
Neg.
132
Bristol
:cry:
You given the pads time to "bed in"? 1000 miles rings a bell! someone can correct me if im wrong :p
strugers1
could have air in the system from the previous owner boiling the fluid
