CarlosSeat2.0
Hello..!
I noticed a strange noise, electronic noise on my ibiza.
When i brake and turn at the same time, it sounds like a low piiiiiiiiiiiiiiiiii noise, and it doesnt go away until i release the brake.
The noise is like the sound you have in your ears before listening 4hrs of loud music.. :D
Any thoughts????
Another problem i have is a vibration of steering wheel when i make a hard turn... (my car has only 3000km)
Carlos from Mexico... [B)]
the two things could be related
you could have a damaged tyre that has a bulge or is out of round, this would cause your ABS to work overtime as the tyre isn't making good contact with the road
get your tyres checked as you could end up in an accident mate
Tanx i will check my tyres.
But i dont think is related. The noise problem is common in other Ibizas.
I always heard it when i arrive home like this:
Try to do that, without engine braking, use only yout brakes. [B)]
is it a really high pitched sort of beeeeeeep? and it stays there even once u've stopped, until you release the brake? If so, this also happens to mine! and ive only done 4k and had it from new.
Thats RIGHT!!! that IS the sound.
..., ive only done 3k and i had it from new too.... and i dont know what it is... :blink:
