brakes
altea-xl
is there a how to on changing rear brake discs and pads? tried searching , has anyone done this themselves? did you find it easy to do? is there anything to watch out for/
cheers
altea-xl
brilliant, just what i was looking for, thanks for that:clap: does it take long to do, me being a novice!!
Nov 2, 2006
1,241
Annaghmore
bebo.com
You will need a 14mm(??) 12 point torx bit and breaker/large ratchet to undo the carriers on the rears, disc doesnt come off without the carrier removed! I tried, no amount of hammering budged it!
Caliper rewind tool is essential as said, pretty easy to do, if your anyway practical an hour will do it, if not comfortable with something like this, get someone experienced to take you through it, essential part of maintenance to get right!
I only used a hammer to loosen the dissc from the hub. however I DID remove the disc without removing the carrier. pull it from the rear first and angle it, it will come off without the carriers being removed (on a 2.0 TDI Sport 256mm disc)
Nov 2, 2006
1,241
Annaghmore
bebo.com
Same discs afaik, had to get carrier off and only then with a tap did they fall off, hammer the living sh**e out of it before and no budge. There is a guide around stating this, maybe design was changed to allow easier access etc?
btw thats a M14 Spline bit you need for calliper removal. just got one today since I am hopeful of a set of 286mm brakes going on soon;)
just got to get them off the back axle of a Mk5 Golf GTI :)
btw anyone know the sequence for bleeding the brakes on an Altea?
1,241
Annaghmore
bebo.com
It is, had found the set i bought in the boot last week. Think blled sequence is usual, start furthest away i.e rear pass side, opposite side, front pass, driver front.
