brakes upgrade from 256 to 280
chisel
265
andyj said:
Will be doing this on my Cordy asap mate ;)
Bought a 280mm set-up off a Mk3 Ibiza, and I'm just going to use the carriers and a set of new discs :D
Andy
and you are not going to change calipers from 280's as well ?
andyj
There's no F in Quality..
From what I've been told, there's no need to change the calipers, as they're identical (or as near as damn it!!!) ;)
I have actually got the full set-up, but byusing the existing calipers, it means I haven't got to mess around bleeding the brakes etc afterwards.. not that it's a big job, just a pain!
Andy
chisel
265
Andy
You are right with this bleeding ;) but there is a diffrens between 256's and 280's caliper ! In SEAT numbers is only very small - 256 - 357 615 123 A
280 - 357 615 123 B
but in live 256 is narrower and you can only put pads 16mm. You can't use 19mm which are made for 280's.
I sill debate about changing carrier and caliper to get the whole set. I don't buy things from the second hand so now you understand my problem ... if it is not nessesary I take only carriers for about 100 quid, if not I take calipers as well for another 80 (cheaper from carriers!)
STi
I'm also doing this conversion as my old discs are pretty much worn out. Only problem is I have to change the wheelbearing housing also as my discs are 239x20. :thumbd:
Are the calipers on the 280x22 set red as they are on a cupra or are they unpainted??
chisel
265
it depends which who do you get, some where red some not
the hoses in 256 and 280's should be the same, shouldn't they ?
